Thermaltake TR2 TR-700 700W Power Supply
Description:
SpecificationsMfr Part Number: TR-700Features:Support the latest ATX 12V V2.3 & EPS 12V standardsHigh current & single +12V rail provides superior performanceUltra-quiet 120mm cooling fan delivers excellent airflow at an exceptionally low noise levelActive PFC with Universal AC inputSupports multiple core high-end graphic cards & CPU (NVIDIA SLI & ATI CrossFire Ready)Heavy-duty protection circuitry of Over Current, Over Voltage, Over Power and Short-Circuit protectionsMaximum Power: 700 WattsInput:Voltage: 100 VAC ~ 240 VACCurrent: 10AFrequency Range: 47 ~ 63HzForm Factor: Intel ATX 12V 2.3Efficiency: Up to 75%Hold-up Time: 16 ms (min) @ 80% of full load at 115Vac/ 230Vac inputPower Good Signal: 100 ~ 500 msPower Factor Correction: Active PFCFan: 120mm Fan with RPM Control ManagementMTBF: 100,000 Hours MinimumOutput: +3.3V @ 24A; +5V @ 24A; +12V @ 52A; -12V @ 0.5A; +5VSB @ 3AConnectors: 1x 20+4pin Main Connector, 1x 4+4pin ATX 12V Connector, 4x 6+2pin PCI-Express Connectors, 8x SATA Connectors, 5x 4pin Peripheral ConnectorsSafety/EMI: UL, CUL, FCCColor: BlackDimensions (WxLxH): 5.9 x 5.5 x 3.4 inch / 150.0 x 140.0 x 86.0 mm
Details:
Description:
Details:
Detail | Value |
Binding | Electronics |
Brand | Thermaltake |
EAN | 0841163045640 |
Label | Thermaltake |
Manufacturer | Thermaltake |
MPN | PS-TR-700 |
Publisher | Thermaltake |
Studio | Thermaltake |
Title | Thermaltake TR-700 700W ATX12V v2.3 & EPS12V Cable Management Optimized Power Supply (Core i7 & Core |
UPC | 841163045640 |
PackageQuantity | 97 |
PartNumber | PS-TR-700 |
ProductGroup | CE |
ProductTypeName | CONSUMER_ELECTRONICS |
UPCList - UPCListElement | 841163045640 |
