These temps ok for a 7750?
558 Views 6 Replies 4 Participants Last post by  wiccan_creed
running 7750 with stock cpu. 38 to 40c idle and max around 54c. i did scrape the stock thermal grease off and apply as5.
1 - 7 of 7 Posts
they are decent i would say for a stock cooler.
The temps are fine, but if you want to OC I suggest you completely remove the old thermal paste instead of scraping it off.
Are you using the stock cooler? (I'm assuming so)
My temps are real close to yours with stock cooling. Are those temps at stock clocks?
They seem a bit high for stock, your stock temps are my overclock temps. I have no clue what case you have so I can not comment on system cooling.
Could you fill in your system specs. It would help tremendously.
1 - 7 of 7 Posts
