interresting ...
Conclusion: Power Saving Can Reduce SSD Performance However, our findings are significant, as they can affect users who may not even know they are running an SSD with the brakes on. In short: really fast SSDs that can deliver 200 MB/s or even more of throughput become limited by CPU performance due to power saving mechanismsâ€"or more precisely, they are bottlenecked by a limited availability of CPU time. This became obvious by switching the various power saving options on and off. We found that the sophisticated power saving mechanismsâ€"such as the Active State Power Management for PCI Express, or the deeper C states that switch off entire functional units within the CPU at a transistor levelâ€"have a noticeable impact on the performance of our X25-E flash SSD. Obviously, the latency added by utilizing the more complex power saving features is significant enough to have to wait for the system to pick up data. The conventional power saving techniques, such as Enhanced SpeedStepâ€"which reduces clock speed and voltage during idle or low load periodsâ€"showed the least impact. This is also the case for C1E mode (enhanced halt). Thus, we recommend keeping both of these enabled, as they contribute to lowering CPU temperature while reducing power consumption. All of the sophisticated power saving mechanisms are questionable for fast, SSD-powered systems. We believe that it does not make sense to go for a hardcore flash SSD product, just to lose performance on the way due to sophisticated power saving features. Check your BIOS options should your SSD performance not be at the level you expect it. |
