1 - 4 of 4 Posts
Hi
Due to space restriction, I am looking for a thin reservoir with a depth of 3.2cm (1.26") max.
Here is what I have found so far, but from what I see they are all discontinued
FrozenQ Flex Tank
10.2 x 7.6 x 3.2cm (4" x 3" x 1.25")
Bitspower BP-WT350P-BK (3.5" bay)
10.3 x 9.1 x 2.6cm (4" x 3.6" x 1")
PrimoChill Typhoon UV Blue (3.5" bay)
Alphacool REPACK-COOLING SLOT-IN (3.5" bay)
Can somebody point out a similar product to me that is still available?
Originally Posted by Deedaz View Post
Would something like this micro res work? Or this bay res?
I have that micro res and it works great (the swiftech one). Check my sig rig and click on the build log if you want to see how and where I mounted it. As with all micro resevoirs you will have to fill it more often but that's a given.
1 - 4 of 4 Posts
