thinkin of moving to Linux
583 Views 17 Replies 10 Participants Last post by  nathris
so i recently got an HP 2133 and it has a vista business and xp pro license with it but i was thinking of sticking linux on it for :turd:'s and giggles.
not really sure what is likely to have the best driver support for it, what is nice and easy to use and what is going to run the fastest on here.
any input would be appreciated.
1 - 18 of 18 Posts
If you're looking for easy to use and well supported Ubuntu is prob where its at. Personally I would install Mint over Ubuntu though, it has some advantages over it and uses Ubuntu's repositories and when you have problems or need a wiki/manual Ubuntu forums/manuals should be applicable.
Read links in my sig and you will avoid hardware problems and get a running start on tweaking out your new Linux system.
thanks, taking a read through now.
Edit: i have been looking at the show your linux thread and love the look of some of arch (really like dangerous hobos setup with open box), how im going to give that a shot in virtual box and see how it runs.
ill be coming back for many more questions im sure, thanks guys
If you really want to get into linux, I recommend Arch or Gentoo. But if you are just messing around and have no true interest, Mint, Ubuntu, Fedora, and OpenSUSE are probably some of the easiest distros I have ever used.
i have used open suse in the past, and i plan on really getting into it, if i find it to much i can always change, but im going to give arch a try
Have fun with Arch. It is one of my favorites.
What is the big deal about gentoo? I like playing games on my computera? Is gentoo better for games then ubuntu?
No. But you do a lot more and have a lot more control over your OS then you do ubuntu.
Ubuntu is very bloated and you dont have a whole lot of control over most stuff, since its all automated pretty much.
Why i like Arch. I chose just about everything thats installed, so I know exactly whats on it and no extra crap. Get it how I like it!
Gentoo is more of an advanced version that involves the options of completely compiling everything in the system from its source specifically how you want it. This can lead to it taking like 12 hours to install because it's compiling the system from scratch, although you can also install from binaries. It does however have a very complete and easy to follow install guide.
It's down to 12 hours? When I installed my first Gentoo box, it took a week to complete the installation!
Really? I installed one on a box like 4 years ago and let it compile before I went to bed and when I got up it was finished. I might have been fairly minimalist about it though since it was just meant to hold apache+sendmail.
Well yeah, this was X, GNOME, mozilla, the whole enchilada.
jeez. i would recommend Ubuntu or preferentially Mint
i need to get moving along to Arch, though...
My friend recommended Xubuntu to me a while back, he said it is very lightweight and should run very good on that computer.
-FilluX
Since you are new to linux, i recommend you to try out few popular distro that people have listed on the thread including fedora, debian, ubuntu variation and few others to get to know linux :)
Now, gentoo is different from others cause it's a source base distro like Purple said hence you will spend quite a bit of time on compiling stuff (system and apps to use thereafter) but looking at your sig rig, i dont think you will have problem with that since your system is very good (fast!).
That is the elegance of gentoo, highly customisable, you can choose features you want for the apps, there is no lack of documentations on the site and in the forum. If you run into a problem, forum is a good source to find an answer quickly as someone else has likely already experienced same problem :p and you can always pop into irc #gentoo for a chat with folks in there for solutions.
As you can see, im a "fan" of gentoo :), I like linux, but you may not like it so you should try it out to see it yourself, you will probably find that you like some features on one distro but not in others and no distro is perfect.
Just my 2pence hehe, sorry for the long post!
If you want something more advanced than an ubuntu varation but not quite as bananas as gentoo, Arch is pretty good. It's a very minimal install in that you won't get a GUI with the install and will get left with just a command prompt and have to install your Xorg, drivers and WM/DE's manually from a package.
But Arch has a pretty strong repository system and they also have a community built repository system, a pretty well stocked wiki, a solid step-by-step install guide and of course an irc channel with 500+ people in it all the time on freenode.
Depends what you want imo, if you want a more painless out-of-the-box ready install go for Mint, if you want a greater opportunity to learn at the expense of some potential headache, go for Arch.
Virtualization.
I have Ubuntu 8.10 running in a virtual machine on my T400, and I don't have to worry about drivers or wireless.
The only thing it doesn't have is any kind of 3d acceleration, but Windows does that better anyway.
Change it to fullscreen and you can't even tell the difference!
1 - 18 of 18 Posts
