Or just get a 5960X.
Server chips usually better binned (and less leaky) than the consumer counterparts and are fully enabled for things like ECC, vPro and DBS that may be useful down the road. The E5-1660 V3 is also fully unlocked, just like the i7-5960X...Originally Posted by CynicalUnicorn
Or just get a 5960X.![]()
I'm not sure what the point of getting a server CPU is though. The 1600 series is comparable to the i7 Extreme series and is certainly an acceptable substitute, but the 2600 series supports things like multiple sockets. They can be used for gaming, but man is it a waste. $500 less gets you an unlocked multiplier and higher stock frequencies. I suppose for Haswell-EP that also means fewer cores, but as it stands, even a 5960X is pretty pointless for gaming.
Mr. OP, by E5-2670, did you possibly mean the Sandy Bridge version? No v2 or v3, just "E5-2670"? That thing is a bit outdated at this point, though it is technically an upgrade over the FX you have. Sidegrade, I suppose, based on the two CPUs' frequencies.
The Xeon E5 V3 family works just fine on the X99 chipset as well. The Xeons are the pick of the litter yield-wise and are the best chips Intel makes..:which is reason enough in my books to buy one instead (as the price difference is usually small). An i7 is, in most cases, just a Xeon reject chip...Originally Posted by CynicalUnicorn
No, I'm familiar with the 1600 series chips being unlocked - even when they have absolutely no reason to be, which is nice - but any multi-socket CPU is locked. That said, it's a bit more difficult to get a Xeon than the i7 equivalent generally speaking, so the i7 isn't necessarily the worse option.
As for the bonus features, games don't need ECC or vPro or anything like that. There's no reason to buy a Xeon for the purpose. Additionally, to use them, you need a server chipset (C600 series IIRC) and not the enthusiast version (X99).
ECC works on many (but not all) X99 boards, including some that accept registered RDIMMs and LRDIMMs as well. This wasn't so for most X79 based boards, however, and I'm guessing it's unlikely to be the case with Purley (Skylake-EP).
Hi, I would like to ask about e5-1660 V3, if it is es cpu, would it be unlocked version too?Originally Posted by lutjens
