Yeah, your board can do RAID-0. I'm not sure if your board has a dedicated controller chip like mine, but if it does, use that for RAID-0. Since it's dedicated to that, the theory is that it's safer for data protection. It would be called something like Jmicron or Silicon Image somewhere in your bios. If it doesn't have either of those, you can still do it on the southbridge. When you are posting the board, do CTRL-I and it will bring you into the ICH9R RAID controller where you can configure the drives.
As for performance, It does make a notable difference. I only have my games installed on my raptors since there's not fault tolerance and the risk of data corruption is substantially higher than with a standard single drive or RAID-1 (which is mirrored drives). It's pretty cool, because I'm usually the first one loaded up in servers and can get prime pick of the red team. lol.
