you'll be getting dual threading per core which will help with triple channel memory and heavy rendering. Cash a concern ? If not then I'd suggest going with a nice i7 d0+x58 setup but you did post this in the Intel section so most of the responses may be supportive of Intel and I too as an AMD guy will recommend that Intel is worth it. Please keep in mind you are running an AM2 socket PII chip. While the AM3 chips may give you a bit more of performance in crease and DDR3 support in the future. GOod luck !
