1 - 20 of 34 Posts
Nvidia Enthusiast
in half life 2 episode 2 if i turn AA off i struggle for 60 fps but with AA i get nearly 200 fps i am pretty sure thats a CPU bottleneck am i right? (I'm getting X3 710 in 2 days)
No thats not a cpu bottleneck, thats prob. a driver problem, if the cpu was bottlenecking the card, once you turn on AA you would see no fps decrease...
Nvidia Enthusiast
Originally Posted by Devilmaypoop
Well, AA taxes the GPU not the CPU, and when it's on its suposte to lower FPS not raise it..
ahaha i knew it i monitor GPU usage without AA the gGPU usage on both GPU's is barely over 20% but with 16XQAA its between 46-68% and framerate is high. so i'm guessing an X3 710 at 3GHz or more will eliminate the bottleneck
Nvidia Enthusiast
so a new CPU wont fix that at all?
I highly doubt that it will, ps: when you turn off AA make sure you have v-sync disabled, since it will lock your fps at 60
Nvidia Enthusiast
i never have V-sync enabled if it isn't a bottleneck then why is it doing this? with SLI disabled the card goes to 99% on the secondary GPU
I used to own a 9800 GX2 and had tonnes of driver problems, ie: GRID would run at 3fps until I disabled sli etc. Therefore I am still leaning towards a driver problem, to answer your question once again based on your description of the problem, it isn't CPU bottle necking...
Nvidia Enthusiast
Discussion Starter · #12 ·
so how do i fix it?
Nvidia Enthusiast
Discussion Starter · #13 ·
Originally Posted by brl3git;11980196
AA stresses the gpu,but if you think its a bottleneck try oc your cpu and check for any difference.
i cant wont post any higher than 2.82 but it is faster at 2.82 than 2.4 almost twice as fast
so its a driver bug?
Originally Posted by philhalo66;11980199
so how do i fix it?
I dont see why you would want to fix it, since with AA enabled you get 200fps, which means better graphics and performance, thats a win in my book...
Nvidia Enthusiast
Discussion Starter · #15 ·
because in BC gpu usage is never higher than 50%
Nvidia Enthusiast
Discussion Starter · #17 ·
Im thinking it may be some kind of bug because if you never get more than 50% usage in bc (a more stressful game to run) and your getting 99% in half life 2 that just doesnt make sense to me.
i agree, when i got my card the PCIE chip on the card wasn't making contact with the cooler and the previous owner ran it like that for weeks could that have damaged the card forever? oh and i it was flickering badly in games until i put thermal pad on it then flickering stopped
the thing i am talking about is the circled thing
Hmm if it wasnt making contact that would deff be an issue,but if you reattached it and you get good performance on different games I think you'll be fine. It is a little odd that this happens in half life though.
Nvidia Enthusiast
Discussion Starter · #19 ·
so you dont think it is damaged?
1 - 20 of 34 Posts
