1 - 20 of 37 Posts
I ordered a X-Fi Platinum refurb from Monarch for $80, well it came today and it had no front panel. Well the card did not look like the Platinum so I ran the Autoupdate to check. ITS A FATAL1TY PRO!!!!!
pink
9 Cans of Ravioli
Its the same name with that kids name slapped on. No?
Well difference is it would have the XRam on it. When I usually do an autoupdate it would of course say the name of the product i.e. Xtrememusic.
It also has the red "F" on the side and I dont think the Platinum has that, can anyone confirm?
pink
Old school
Agreed. Why is this guy such a hype? It's basically the same product but usually different looks.
I am pretty sure thats what the platinum is except with the panel. They both had the extra xram. So I guess it would detect it as a Fatality pro
Discussion Starter #6
Guys I dont care about his name, I care about the XRam. And I got it for cheaper then my Xtrememusic!
The Platinum does not have the Xram ony the Fatal1ty and the Elite Pro do.
pink
the Fatal1ty version has the XRam... but you still have no front panel...
Discussion Starter #8
Correct no front panel was in the box. I emailed them about this so maybe they wills end it as it said nothing in the sale about no including it.
pink
fatlity pro? do you mean FPS?
http://creative.com/products/welcome.asp?category=209
The fatality FPS is actually higher than the platinum. The platinum doesnt have XRAM.
The XRAM cards have a LED on the top of them. I believe the 2 cheaper versions do not.
Elite Pro(has XRAM)> Fatal1ty FPS(has XRAM)>Platinum(doesnt)>ExtremeMusic(doesnt)
Discussion Starter #12
And mine has the LED F on it so I think I actually have the Fatal1ty here. I am going to look a litte futher into it. I am gonna read some reviews so see some detailed pics. I have not seen any solid reivews of the Platinum though?
I will take it out and snap some pics, maybe someone can confirm this with there own Fatal1ty card.
Also it did come in a Platinum box.
pink
Then you have the FPS, which is a steal, even if you didnt get the faceplate!
http://www.newegg.com/Product/Produc...82E16829102190
There is the one you should of got. It doesnt have the F led. Lucky.. the store must of messed up your order. I would keep the FPS though.
Discussion Starter #14
^^As much as honesty is the best policy your damn right I am keeping it lol.
pink
lol thats right, for some reason I was thinking elite. Sorry. That is pretty cool though. hmm maybe when I get my extreme music back from rma it will be a Fatality one....
Discussion Starter #17
I cut my finger bad removing it also, however the pics turned out crappy with the card on my desk vs the Xtrememusic.
This is great as I ordered 3 red Thunderblades also lol.
pink
he kicks ass on quake 3 and isnt bad on cs:s
id like to 1v1 him somtime.
Awesome I was gonna get mine, but the shipping required a signature and I wasn't home so I'll have to wait till Monday.
1 - 20 of 37 Posts
