1 - 3 of 3 Posts
Hi all,
I have a question, I would like to overclock my 1950x to 3.9.
I have difficulty finding CPU voltage, basically my system unstable. Temperature is good.
Do you have any suggestions or recommendations?
Thanks!
Hi all,
Thanks!
Need more info. Memory type, motherboard, voltages tried, stress tests used. Etc, etc. Other than that start with Vcore 1.35v and play with your CPU LLC till your voltage runs stable with minimal vdroop. Your looking for voltsgecto stay around 1.4v when benchmarking.
Totally Tubular
Yeah the typical Threadripper can get around 4.0GHz with around 1.35v. Mine can get 3.9GHz at 1.2125v and takes the full 1.35v for 4.0GHz.
1 - 3 of 3 Posts
