1 - 6 of 6 Posts
Programmer
For some reason, one of my computer fans is making a slight high pitch ticking noise. Not so much ticking, but as i power down my computer, the high pitch noise reduces in speed as the fans reduce in speed to come to a hault. Could something be slighty vibrating on the case or maybe the fan on the HS? It's extremely anoying now. It started doing is a couple of hours ago since i cleaned out my PC.
Thanks for the help
What kind of fan is it? the mount could be loose..something could be loose near it. Or one of the berrings could be shot? I know they dont sound very nice with a worn berring =/ or even a large amount of dust in around the berrings.
Are you sure nothing is touching the fan blade? If you were recently inside the case and the noise started afterwards my first guess would be that a wire or piece of debris is touching the blades.
Motorola 68040
If the balls are out of alignment you may have to manually push the fan in the opposite direction.
1 - 6 of 6 Posts
