tighter timings vs speed?
877 Views 10 Replies 8 Participants Last post by  Zeromark
Hello fellas its been a while but im back with a question.
Ive got some 2 x 2 gskill ddr2 at 500 mhz. These are running at
5-5-5-15. Now i changed it to 400 mhz, and i could get the timings to
4-4-4-9, which i think is pretty damn good. What im wondering, and im not sure if theres a difinitive answer, is are smaller timings going to show better performance than 100 mhz,, or 200 because of ddr2?
Thanks
Oh also i am now running at a 1:1 ratio on cpu/ram which may also be good
1 - 11 of 11 Posts
From my experience 500 with those timing would be faster. Try a program like Everest, it has a memory speed test. Not sure thoguh 1:1 and tighter timing may mean better performance. Try Everest see what kind of numbers it spits out.
i ran super pi with my 2x1gb reapers, my results got worse going from 1170Mhz @ 5-5-5-18 to 800Mhz at 3-3-3-9, and the bandwidth was near or over 10 Gbps at 1170Mhz, but wasnt near as high at 800Mhz
good question really, ive had that go around in my head, but i figured that high speed over timings as speed makes up for the timings.
For intel chipsets, higher bandwidth with looser timings will get you better performance. On nvidia chipsets, it doesn't matter as much.
Speed wins all. If you are able to get max speed out of them with tight timings then you are golden.
Here is the same FSB (410) with the same multiplier, but with different RAM timings and speed because of ratio:
4-4-4 1:1
5-5-5 4:5
I gain about 10% at these settings
I've seen a few who've had better scores with lower latency vs. speed, but as a general rule, speed wins out on Intel based systems.
Here are two extremes
5-5-5 5:6
Attachment 99922
3-3-3 1:1
Attachment 99923
I must say though, this ram at 3-3-3 667Mhz is just as snappy as when i put my CPU up to 3.6-3.8Ghz. My CPU is only at 2.5Ghz, its much snappier then my CPU at 3.2Ghz with my ram at 5-5-5 1120Mhz. Which is really odd since my FSB CPU and ram are all slower?
That is very strange. Have you run SuperPi at both speeds?
Testing in Superpi isn't good idea, because it likes tighter timings and in games/other benchmarks higher clocks will be better. Anyway, the difference will be about 1-2% I guess and something like 1000 5-5-5-15 is in 100% sufficient
Overclocking CPU/GPU gives better effects
1 - 11 of 11 Posts
