OK, since I need $$ and am selling my H20 gear, I bought an Xiggy S1283 to get me by. This is my first heatpipe-direct cooler, so I am looking for advice with TIM application.
I have seen pics and heard of people filling in the gaps on the HS with TIM prior to installation. To me, that seems like a way too much TIM. Is there really a need to do this or is just making sure that the contact areas on the heatpipes and IHS are covered?
I guess I just don't see how it helps. Does enough heat travel laterally between the pipes to justify that? I have always been a believer in less is better. I may have to try some experiments myself. I'd like to see that review, though.
The review i am mentioning is where that pic comes from and they did some testing as to what is the best application method...i would have to guess it helps add more heat transfer to the pipes
Yeah - its tricky. I applied the TIM to the base of the cooler and wiped it off (with a finger wraped in plastic wrap) so on the grooves where filled. I then did the two strips - as recommended. I guess the theory is that that method eliminates air pockets
I would assume that you just apply and clean off with a CC or another straight edge.
I used a toothpick my first time around and got great temps...i was in a big hurry my second time around so i had it done within seconds and i was expecting to have botched it but im still loading at very low temps so its hard to really screw it up
Just line those grooves and get as much paste as you can in there then finish up with the two lines
I went from a zalman 9700 to a xiggy dark knight and this is what i did.
I did not use the pre apply method to fill the gaps of the base and heat pipes i just run very thin lines of mx-3 down the base dividers and mounted the cooler. I fired it up and instantly found that there was a 6c drop in temps.
I don't always like to do what everyone else is doing...sometimes it works sometimes it don't! GL!
Overclock.net
