Time for an upgrade
437 Views 10 Replies 5 Participants Last post by  H4rd5tyl3
So I've come to the conclusion that I need to upgrade the PC, but I'm having trouble deciding on my purchase. I want to spend about $200, and I think i've boiled it down to two options...
#1. Replace CPU with 965BE C3. Small upgrade, but might be worthwhile.
#2. Two new HDD's (maybe WD Caviar Black
) in RAID 0. The only problem with this is that I 'd like to copy my old HDD over to the new RAID array, but I'm not sure if I can use Norton Ghost (or some other program) to do this without issues.
Any input is welcome. +rep for insightful suggestions.
1 - 11 of 11 Posts
In my opinion, the hard drive option is the best.
It will aid your boot times greatly, and everything will be faster (loading games, booting into Windows, etc.), desktop speed is actually dependant on the hard drive speed more than anything else, so everything around the operating system will seem MUCH faster.
You can use Norton Ghost to make an image of your drive, yes.
So using Norton ghost won't be an issue going from a single drive to a RAID 0? Recommendations for a drive? I'm looking for at least 640GB, but speed is the most important factor.
In that case, I'd get the Western Digital Caviar Black 640GB drive. They're amazing - faster than any other drive in the Caviar Black range (Except the Caviar Black 2TB) due to the size of its platters: 2 320GB platters, instead of 250GB platters in every other drive, except the 2TB, which has 4 500GB platters. The reason this matters is that it has a higher data density than most other drives.
And I'm not 100% sure - I've never done it before. You should maybe look at a guide or something. I don't want to say anything with the risk of not being right.
http://ghost.radified.com/
That should help (I think).
Whatever you decide to do, good luck!
Thanks for the input.
Exactly what I would have said. The WD Black is hard to beat in terms of speed and size.
You have a very fast processor, Why upgrade?
Go for the HDDs!
I believe the SeaGate 500GB 7200.12 Drives are just as fast as these drives, but obviously they're smaller in terms of capacity, and SeaGate drives (generally speaking) aren't as reliable as Western Digital.
You can't go wrong with the Caviar Blacks.
My only concern is the capability to copy my OS to the RAID array. I only have the Upgrade Media for Win7, so a reinstall is not an option. Don't I need to load the RAID drivers during the OS install for it to wrok properly? If I am merely copying the drive over, then I don't know if it will work. what are my options here?
Another thought... what about replacing the GX2 with a single GPU card such as the 4890? More memory, no more microstutter... thoughts?
I'd say go for it. Either that or the HD upgrade are your best options. I actually saw a 4890 go for 90 bucks on craigslist in my area about 2 weeks ago! I know it was a steal but I didn't really need/have money for it at the time
1 - 11 of 11 Posts
