1 - 10 of 10 Posts
I've have my JVC Marshmallows for a while, and I'd like to try something new. They don't really stay in my ears too well, and there's a lot of noise from the cable rubbing on my clothes.
I primarily use these at the gym - lifting and running, so they should be relatively inexpensive and preferably have little noise from the cable.
I was looking into V-Moda Fazes, but I don't really want the microphone bit, and $40-50 is a little more than I'd like to spend.
Thoughts?
Thanks!
Discussion Starter #4
Suggestions on tips? Or will basically anything work?
i think anything will work. I bought some cheapo ear buds that cost me only $10 and i replaced it with them. although that cheap pair of ear buds sounds awesome for a cheap price. My Marshmallows have been through a lot this past year, but the wire is starting to cut at the plug so i bought new ones online.
step up to a pair of JVC FX-66. Small increase in price, more comfortable and sound better. Still an audio bargain IMO.
tbh, I'd go the MeElectronics range if you want decent cheap earphones. Much better than Marshmellows these days.
Discussion Starter #10
I've had them before. I'd rather try something new. Thanks though.
Originally Posted by Fear Asmodeus View Post
Well there a lot of different types of tips to choose from. This post on head-fi should show what types of tips they are and what you might want to look for:
http://www.head-fi.org/forum/thread/...ial-comparison
Most of those should fit the JVC but always check before you buy.
Thanks for the link!
Originally Posted by Black Cerberus View Post
Koss ksc75 Amazon.com: SportClip Clip-On Headphones: Electronics
Mine stays on great.
No thanks. Not a fan of the style., and clip-ons tend to bug my ears.
Thanks for the tip.
1 - 10 of 10 Posts
