TJ07 best case ever!!!!!
960 6
1 - 7 of 7 Posts
I will be defintly getting that case, its so perfectly designed!, im in love with it......nice post man
and it better be good with a pricetag of $350 smackers!
Why do I still like the PC V2000 Better?
Firstly, this case looks almost exactly the same.
Secondly, the airflow in this case look horrible. I mean, the "cool" air form the 92mm fans gets ventilated directly out by ther top 120mm fans. That leaves little to no airflow in the front of the case and the middle.
The space at the bottom looks very small compared to the PC V2000. You would have trouble fitting a decent WC system in there.
Also, the Lian is $100 cheaper.
But the PC V2000 does not have a removable mobo tray. That is about the biggest difference.
1 - 7 of 7 Posts
