Under load it gets to 65 degrees c. The multiplier is x20 and the vcore is 1.450V and its at 4Ghz.
Is this a normal temp for my overclock?
...Originally Posted by Ulatec;14166095
Stop trolling please? Just because someone is an Intel fanboy...
Reseat your cooler, reapply thermal paste, clean HSF of dust and undervolt. If this doesn't fix get a new cooler.Originally Posted by amdcpu4life;14166152
It's Idle temp is 55... wow... Sorry i know nothing about temps and what they should be.
1.35v of course. Just decreasing your clockspeed wouldn't affect temperatures at all. It's all about voltage.Originally Posted by amdcpu4life;14166155
Down clock to 3.8 and keep the vcore at 1.450v? or 1.350v? It was stable @ 3.8 with 1.350v.
Is isn't a troll, it is a pure reality (and yes I have intel processorOriginally Posted by Ulatec;14166095
Sent from my Nexus S using Tapatalk
Sooo wrongOriginally Posted by Devilmaypoop;14166159
People get rep for any nonsense these days..Originally Posted by amdcpu4life;14166165
+rep for you.
Idk depends on the CPU architecture really cause I'm running a AMD Phenom II X4 B55 at 4.2Ghz on stock Voltages and I haven't registered a major Difference in temps, maybe just a 2~3 Difference but when I Up the Voltage my temps jump like crazy like 7~10 Degree difference.Originally Posted by ronnin426850;14166173
Sooo wrong Of course decreasing clock speeds lowers temps.
How do you explain why temps raise if you OC even if you don't raise above stock voltage?
Just decreasing the clock speed, may drop your temp. The voltage is the same, but the amperage will be lower --> lower TDP --> less heat.Originally Posted by Devilmaypoop;14166159
I know that, but just 200mhz won't affect them at all. Even 400mhz doesn't affect temperatures for me at all if I don't decrease voltages too.Originally Posted by ronnin426850;14166173
Sooo wrongOf course decreasing clock speeds lowers temps.![]()
Yup, but clock speed still affects much less. He was asking if 200mhz would drop temperatures, it wouldn't.Just decreasing the clock speed, may drop your temp. The voltage is the same, but the amperage will be lower --> lower TDP --> less heat.
I got a infraction for saying someone was trolling, you should edit your post to remove that part.Originally Posted by Ulatec;14166095
