To much ram power? Hurting O/C's?
286 3
I am running the memory in my specs. I have it running at 3.0v right now (highest to maintain warranty). Is it possible that I have it too high and is actually hurting my OCing? I'm at work right now so i cant test it, but i would like some input before I got home. The best I have been able to do with the ram before is 225mhz.
-Allen
p.s. Link to ram:
http://www.newegg.com/Product/Produc...82E16820145450
1 - 4 of 4 Posts
Many times when people max out at 220ish HTT it is because they forgot to turn down their HTT multiplier.
In general, uping the volts is the last thing I do. I find the max I can go and be stable...then up the volts a little and repeat.
I have seen systems that could get impressive OC's on stock voltages and uping the volts furthur didn't help any either.
I have the Corsair XMS PC3200 RAM but not the kit. I am not very happy with BTW.
The max I have been able to get out of it is 220Mhz - Stable-
even at the higher voltages.
heck - mine won't even POST above 2.7v
It depends a lot on the chips used on the DIMM.
i think you should do what vagrant suggested...reduce the volts and start again from ground up...if i am right i had the same ram and did do a 237 b4
1 - 4 of 4 Posts
