1 - 14 of 14 Posts
I have 2 x160GB SATA2 Samsung Spinpoint 3.0Gb/s drives and was considering a RAID 0 array, would this be better as a boot drive than say a 250GB Seagate Barracuda Perpindicular on it's own?
I would say yes. Raid those puppies <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
I remember when......
Those drives in RAID 0 would give you faster read times and more space than a single 250GB.<br />
<br />
As always, it's a good idea to partion the array to keep your OS seperate from your files <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> I use a 50GB partition for mine.
Discussion Starter #4
I'll be buying a 3rd hdd regardless for back-up.
RAID them, you'll be impressed with the read times you'll get from them. Faster game map loading and boot times.<br />
<br />
If you're getting a third for back up you might as well get 2 small 34GB Raptors, put those in RAID and use that for software and the OS and use the other 2 HDDs for back-up.<br />
<br />
It really depends on what kind of backup HDD you want to get
The problem is that the pair of Raptors will run him up over $200, while a good 250GB hard drive can be had for $80. I'd just RAID the ones you have and add a third drive for backup.
Raptors are pretty expensive, but in a RAID, they can't be beat. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> Go for the RAID for sure though. I will never go back. <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Discussion Starter #8
Raptors are kinda dumb for RAID imo, heh i mean everone knows that RAID stands for "Redundant Array of Independent (or Inexpensive) Disks".<br />
<br />
Now this really wouldn't apply with Raptors would it? lol
It would beat anything in performance though <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" /> (it's Independent... not Inexpensive.. RAID is often used in SCSI environments also, with 15k drives that run into hundreds of dollars, sometimes more than $1,000 per drive)<br />
<br />
However, in your case, since yuo already have the Dual 160GB, just get a back up drive and be happy <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>Thumper</strong>
</div>
<div style="font-style:italic">Those drives in RAID 0 would give you faster read times and more space than a single 250GB.<br />
<br />
As always, it's a good idea to partion the array to keep your OS seperate from your files <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> I use a 50GB partition for mine.</div>
</td>
</tr>
</table>
</div>It will absolutely not give faster read times. It will give more mb/s, but not faster read times.
Access times are worse in RAID, read times (bandwidth) is better.
Discussion Starter #12
You don't need to tell me about such things, i already know SCSI speeds and costs involved. I was simply enquiring about Perpendicular Technology and what effect it would have against common RAID 0 solutions in terms of performance between the two...
Administrator
RAID0 would benefit you greatly performance wise..System wide of course. However becarefuk as if RAID0 Array mucks up you have lost everything. RAID 0+1 would be better but you need 4 hdd's for that. 2 running RAID0 and the other 2 imaging the HDD'S for backup.
The RAID would outperform a single perpendicular Seagate drive<br />
<br />
Again, my recommendation is to use the two 160GB drives in RAID, and add a back up drive.<br />
<br />
There is nothing wrong imo to reply to your (incorrect) statement that RAID is for inexpensive drives only <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> That reply was in addition to my advice to stick with your current drives and add a third drive.
1 - 14 of 14 Posts
