I've found myself with some free time, so I want to try out this Windows 7 OS. I'm planning on making a partition on my secondary drive (this secondary drive has all my apps and installed programs, not Windows Vista) and then installing Windows 7 on there. Only thing is, how would I go about dual-booting? I've never done this before hah..
Right-click on "my computer" and select "manage." Then, under the "disk management" screen, right click on the physical drive you want to make a new partition on and "shrink volume" to the size of the new partition. Right click the new "unallocated" partition and click "new volume" and fill the the volume label and select a drive letter.
However, windows disk management is not always able to work around fragmented files, so if it's a drive that has been used for a while and isn't well defragmented, you might not be able to "shrink volume" to a large enough partition size for a new OS.
Best of luck.
Also, it will ask you which OS to boot up when you startup the computer.
Best of luck.
I'm partitioning on my 250GB HDD. I was given around 110,000MB worth of space. I'm just gonna take 50GB (should be more than enough) and work with that from there. Thanks!
Yeah, Windows 7 will do the boot loader for you so you don't even have to worry about that. Just make the partition and make sure that is the one you select when you install. And backup everything important. As fail-safe as it is, something can always go wrong.
Originally Posted by tofumonster
Oh and where would I find the download...
Or is it unavailable now? :[
It's not available from MS anymore, but you can still get a CD key from them. (Not that you'd need it considering many people were given the same keys which work an unlimited amount of times which can easily be found on OCN.)
When I'm done with the trial, how would I go about adding back the partitioned space back into my D drive?
You just need to restore your boot record using EasyBCD or the like. Then just go the same way you made the partition and delete it and then extend your Vista one to retake the 7 partition.
Overclock.net
