Hey,
Updated 11/06/19
"Some followup guide*
**3/30/20
Some new updates, new mousepads.
Skypad Glass Mouse Pad
Skypad Steel Mouse Pad
Incoming Aluminum MousePad polished-Sandblastedx3 should be the same as the SS SX hopefully, I will update when it arrived.
1 . Another good information will be if the item wears out quickly or at all in some /month/years
2. Please if you can add what type of hard mat is it ( Ex: Aluminum, Glass Coating and such ) inc for the cloth mats too.
3. If you can write the name of the mouse pad alone/solo after the full write up.
(I'll make a poll vote when we have enough mousepads to vote for)
after we have enough hard mats, we'll take the suggested cloth mousepads for another poll.
Please let's make a list of the top Hard mousepads for dedicated gaming buying guide, cause reviews are ok, but how do you know what mousepads are currently best to look for? easy question, hard answer.
For my top list I have currently one wish, to get a mouse pad exactly the same as SteelSeries SX which is my most true mouse pad ever, nothing can win this mouse pad.
What I know and can recommend are from durability-speed-precision
I am not gonna recommend at all on Razer mousepads, I had enough of them because there are others way better and cheaper.
Please suggest yours, I tried a variety of mouse pads including the QCK, I didn't like it or any cloth mousepads, so make sure you suggest only Hard pads first and then you can take notice about very good cloth pads.
Request :
Please notify me if something is not correct and if you can fill the unknown ones.
ARTISAN Mousepads Review
https://www.overclock.net/t/1321688/artisan-mousepad-review
Currently Full List :
Material : Hard - Glass - Aluminum - Steel - Plastic - Coating :
Numbers 1,2,3 Notice ( You must keet the mouse pad oily with Silicon-Teflon based oil )
1. Skypad Glass Mouse Pad ( Tempered Glass ) ( Better than SS I-2 )
2. Skypad Steel Mouse Pad ( Steel ) ( Way better durability than Aluminum almost smooth as glass)
3. Geared Gaming Surface Titan ( Anodized Aluminum ) ( Highly Recommended by me ) (seems to not selling anymore)
ModMyMachine Slamepad Aluminium ( Anodized Aluminum ) ( ( Best with highest durability )
Alugraphics GamerPro ( Anodized Aluminum )
RATPADZ XT ( Tough polymers )
C4 Ngen ( PFTE Coating ) ( Quick Review https://www.overclock.net/t/1507448/top-available-hard-cloth-mouse-pads/190#post_23107310 )
Steelseries 9HD ( Plastic )
Razer Scarab ( Fractal 2.0 coating ?)
fUnc F-10 XL ( Smooth surface ? / Polycarbonate )
fUnc F-30 XL ( Rough Surface/ Polycarbonate )
Zowie Swift ( Plastic )
Artisan Shiden ( Glass Coating )
Aristan Shiden-Kai Mid ( Glass Coating )
Xtrac Ripper ( Silky smooth surface )
Corsair MM600 ( Hard Plastic )
Razer Destructor 1 , 2
( Read ) https://www.overclock.net/t/1507448/top-available-hard-cloth-mouse-pads/300#post_23527563
https://www.overclock.net/t/1507448/top-available-hard-cloth-mouse-pads/390#post_23648455
Hybrid:
BenQ ZOWIE G-SR-SE DIVINA Edition - Does not wear out - has a smooth top
Zowie G-TF Speed ( Cloth + Plastic )
Xtrac Hybrid ( Cloth and plastic surface )
Soft:
BenQ ZOWIE P-SR Competitive Gaming Mouse Pad - Medium - Does not wear out
Puretrak Talent
Puretrak Stealth ( Smaller than the normal )
Steelseries QCK+
Steelseries QCK Heavy
Roccat Taito
Artisan Hein
Corepad Deskpad
Glorious Extended Gaming Mouse Mat
Allsop Raindrop XL
HandStands Super Mouse Pad
OUT OF THE RECOMMENDED LIST :
( People said bad things and issues with those mouse pads )
Mionix Propus 380 ( Ultra-fine texture ? ) ( Durability issues )
Corsair MM400 ( Polycarbonate ) ( Sensor 3310 issues https://www.overclock.net/t/1507448/top-available-hard-cloth-mouse-pads/240#post_23173630 )
Logitech G440 (solid polymer core/Polycarbonate) ( Durability Problems - Read ) https://www.overclock.net/t/1507448/top-available-hard-cloth-mouse-pads/140#post_22983677
Artisan Hayate ( Very low Durability )
Zowie G-CM Review ( https://www.overclock.net/t/1319273/zowie-g-cm-review )
(May not lay flat easily depending on the surface without having to spray water under mat periodically.
https://www.overclock.net/t/1507448/top-available-hard-cloth-mouse-pads/540#post_23950766 )
Updated 11/06/19
**3/30/20
Request :
Hybrid:
Soft:
Puretrak Talent
Steelseries QCK+
Roccat Taito
Artisan Hein
Corepad Deskpad
Allsop Raindrop XL
