Top CINEBENCH R15 CPU Scores
262721 1489
MAXON has released their latest benchmark software: CINEBENCH R15
Download MAXON CINEBENCH R15 from: HERE
In addition to filling out the specs/score form, you will need to provide the following in your post, to stay listed in the chart:
OCN Username -- CPU -- CPU Clock -- CPU Score
CPU (Single-Core) scores are NOT required, but the more numbers the better.
I will fix any errors in the spreadsheet, and remove invalid entries periodically. If there are errors in the form I will correct them according to the user's post and screenshot.
I will also update the post links in the spreadsheet at least once a week.
*Only the 30 highest scores, per user and processor, will be added to the "Top 30" chart.*
https://docs.google.com/spreadsheet/pub?key=0Avrck3jWivLcdENEb3dGangxTFh5UVRYVDBtOWp3RXc&output=html&widget=true
Full Page Spreadsheet ----> CINEBENCH R15 Results
https://docs.google.com/spreadsheets/d/1IWcGoB7jVTz5iusDkVwU26AaMbzRfE_VIY9d7QzZyhc/pubhtml?;headers=false
Reactions: topdog and shadman
1 - 20 of 1490 Posts
Cyro999 -- 4770k -- 4.6ghz -- 952/185
Dunno if the single core is max, and i could probably hit 950 with 4.6/4.0 if i used safe mode or pressed the button enough times or put RAM to unstable clocks.
Do i need the other stuff? The shot's a few days old and i'm testing other settings. I could have pasted notepad on top
Luciferxy -- Xeon E3-1230V2 -- 3500 -- 638
Ran mine as well. Mediocre Oc, 3930k 3.9Ghz, ram is 1866 9-9-9-27. CPU score 1000 (after a few runs, was 992, 998, then 1000
Had my buddy run it, he's got a 3930k as well @ 4.9 Ghz and he got 1199. Just for some reference.
OC...D
jpmboy -- 3930K --- 5.0 --- 1283
OC...D
Sorry OP - updated score
jpmboy --- 3930K -- 5.0 --- 1287
mtbiker033 -- 4820k -- 4.6ghz -- 807/164
OC...D
OP - nice bench thread. +1
