Top CINEBENCH R15 CPU Scores
262995 1489
MAXON has released their latest benchmark software: CINEBENCH R15
Download MAXON CINEBENCH R15 from: HERE
In addition to filling out the specs/score form, you will need to provide the following in your post, to stay listed in the chart:
OCN Username -- CPU -- CPU Clock -- CPU Score
CPU (Single-Core) scores are NOT required, but the more numbers the better.
I will fix any errors in the spreadsheet, and remove invalid entries periodically. If there are errors in the form I will correct them according to the user's post and screenshot.
I will also update the post links in the spreadsheet at least once a week.
*Only the 30 highest scores, per user and processor, will be added to the "Top 30" chart.*
https://docs.google.com/spreadsheet/pub?key=0Avrck3jWivLcdENEb3dGangxTFh5UVRYVDBtOWp3RXc&output=html&widget=true
Full Page Spreadsheet ----> CINEBENCH R15 Results
https://docs.google.com/spreadsheets/d/1IWcGoB7jVTz5iusDkVwU26AaMbzRfE_VIY9d7QzZyhc/pubhtml?;headers=false
Reactions: topdog and shadman
1461 - 1480 of 1490 Posts
Update: Carlhil2 - 9800x @ 4.8 GHz(2 cores at 4.9Ghz)- Ram @3600mhz- [email protected] score - MT 2191-ST 220
Old to Overclock.net
GTZ -- R9 3900X -- PBO (all core around 4.05, single core 4.615) -- Single Core 216 -- Multi Score 3208
Playing with the FX
FX 8370e at 5115 mhz
826 multi
124 single
Reactions: AVATARAT
I think this bench result killed my first Zenith II Extreme mobo. I'll start benching it again very soon.
https://hwbot.org/submission/4308295_
Rage Set - Threadripper 3960X - 4475 - 6733cb
opoi63 -- AMD x6 1100T -- @4514 -- 688
opoi63 -- Intel i7-4790K -- @5012 -- 1040
3800XT @ 4600MHz allcore
I know R15 is old new but I still like using it. Here is my score with my 5800X
GTZ -- Ryzen 7 5800X -- @ stock -- 2586 M | 268 S
2468645
Reactions: vmanuelgm
Mentally Insane User
You took the number one spot for single core. Who would have ever thought you would see a AMD CPU in the top spot single core and most if not all those Intel CPU's nearby are on LN2.
Oh snap, I ran a 271 single core last week while playing around with PBO and Curve Optimizer on my 5950x. I’ll see if I can recreate that run (or better) tomorrow.
That was stock, with my strongest core I got 271 at 5.0. But alas was unstable due to cooling.
That is what I got tweaking with it. Pretty easy to hit. But my cooling was not up to it.
