Ok so I'm very new to even the concept of a VPN. I recently purchased Cisco VPN Client but have no idea how to configure it. I got it for what I believe to be geospoofing. I'm looking for more anonymity. I'm on a home network with a cable connection via wireless receiver. These are the fields in the configuration that i dont know what to input.
Connection entry:
Description:
Host:
Then I'm looking at choosing either group authentication or mutual group authentication or certificate authentication. I'm assuming i want the first option, so the fields needed here are
Name:
Do I choose these myself or is this for access to the wireless connection from my router?
Lastly, I have the option of enabling transparent tunneling, which if enabled I need to know if I want IPSec over UDP or TCP.
And there is a box to check below this for "allow local LAN access"
Any help would be extremely appreciated as Ive attempted to get this information on the net unsuccessfully and I am at my wits end! thanks in advance!
Connection entry:
Description:
Host:
Name:
