Physx and folding. Nice.
Albatron today introduced a new graphics card touting compatibility with single-lane PCI-Express interface. The Albatron GeForce 9500GT PCI-E 1X, as the name suggests, is an entry-level graphics accelerator which is compliant with most of the current generation standards. It is based on the NVIDIA GeForce 9500 GT, which gives it a fair chance to make it to HTPCs and multi-head display setups. Being based on PCI-E x1 bus, the card will fit into a PCI-Express slot of any length and generation. The GeForce 9500 GT provides 32 stream processors, and is CUDA-supportive. The card packs 256 MB of DDR2 memory clocked at 1400 MHz. The core and shader domains are clocked at 550 MHz and 1375 MHz respectively. The card uses a half height PCB, and comes with a low-profile bracket. DVI and composite connectors are provided on the card, while a header extends out a D-Sub connector. HDMI is supported by means of a dongle. The card relays audio to the HDMI connector from an SPDIF source. Albatron will price this card well within the US $100 mark. ![]() |
Originally Posted by Andr3az ![]() wat? You don't hacksaw a card lol You just remove the back end of the x1 slot and place the x16 card there. Link to the guide: http://www.overclock.net/overclock-n...e-adapter.html In this thread he uses adapter, but you can do the same with the slot on your mobo. |
Originally Posted by Andr3az ![]() PHysX is not THAT useless.. You might get few extra FPS running PhysX card ( with PhysX games tho ). |
