1 - 16 of 16 Posts
Cooler Master is preparing a new HTPC case for mini-ITX form-factor motherboards, the Elite 120, which was pictured at CES. It is built mostly from SECC steel, but its front bezel is made of aluminum. The case measures 240 x 205.6 x 382.5 mm (WxHxD). It features one 5.25-inch drive bay, four 3.5-inch bays, and two 2.5-inch ones. The only fan included with the case is a 120 mm front intake, but there are provisions for more fans, at least one on the side. Its front-panel includes one USB 3.0 port, two USB 2.0, and audio jacks.
Source
Doesn't look like an enthusiast class based on the dimensions and specs. By fitting an ATX power supply the back will be severely cramped and this might even be a single slot case from the looks of it. I give it a 6/10 only for the fact that it holds so many drives.
Not sure why you'd want to put an ATX PSU in an ITX case...
Discussion Starter · #6 ·
Been doing some searching on this case and the best info I've found is on the video below:
At about 1:55 the CM rep states that this will hold dual slot full sized GPUs and ATX PSUs (and looks like it has room for a 5.25' external bay). Hard to believe yes, but I managed to squint out the dimensions off the original photo and here it is compared with a SG07:
http://sizeasy.com/page/size_comparison/34008-SG07-vs-CM-Elite-120
This apparently releases Q3 2012 so I won't be holding my breath but I do look forward to additional specs as they are made available.
hey hey....I have a full sized PSU in my ITX case!!! lol
So it's a microwave?
Maximum effort.
The design is nice, and I guess if you want an HTPC that can play BF3 this is right up your alley. Personally the depth is a bit much for what I think an HTPC should be, but I guess that class of computer is growing broader and broader.
Discussion Starter · #16 ·
Originally Posted by _GTech View Post
Price?
All Looks aside, I like the interior design, seriously.
I could always remove the Logo and like have someone paint the front for me.
Will retail for around 50 Euro while availability is in Q3. With the recent slew of Z77 ITX boards being announced, this should be quite popular.
I kind of like the front panel but will definitely use slot covers.
1 - 16 of 16 Posts
