A little pricey for me.
Cooler Master is ready with a new 120 mm PC fan with the Excalibur. The fan is characterised by its perforated circular metal fan frame, and detachable fan blades that makes cleaning easy. It measures 120 x 120 x 25 mm, and is PWM controlled, spinning between 600 and 2,000 rpm ± 10%. At those speeds it pushes between 26.4 and 85.6 CFM of air, 0.75 to 3.53 mm H2O air pressure. Its noise output is rated between 13 to 30 dBA. The barometric ball bearing is said to more than double its life time over conventional fans. The Cooler Master Excalibur 120 mm fans is expected to reach stores soon, priced at 17.90 EUR. The fan is fit for use in cases, CPU coolers, and radiators. |
