[tPU] CoolIT Systems @ CeBIT
1879 Views 19 Replies 18 Participants Last post by  SLeeZeY
I have a CoolIT Domino A.L.C., and love it. Can't wait to see the prices of some of these cases.
Originally Posted by techPowerUp!
The CoolIT Systems booth has grown considerably in size, over the years. Even though their booth is not as big as at CES, the crowd is basically running them down. The Domino A.L.C cooler - of which you can expect a review soon - is being accepted by the public and the industry quite nicely. They are showing off two custom made PCs, which are made by Kobalt Computers. Both are cooled by CoolIT technology. The one which really impressed me - both due to build quality and the amount of CoolIT hardware used is the black unit. These two are probably the craziest systems I have seen this year around.
Source
1 - 20 of 20 Posts
that looks sick!!
i like it
Now that is restrictive!!!
That tubing looks so damn thin! They should put some decnt tubing in there.
No offence, I actually like the Ice Window they did better, maybe if your crossed it.. that'd be REALLY sexy. (Your way of icing the windows in their shape of it).
It may be restrictive, but it's still sexy... Get a few pumps for that. xD
Sledgehammer I thought your first pic was just of saran wrap until I saw the second pic.
Once again, I'm sure CoolIT doesn't know anything about watercooling RIGHT? I MEAN SINCE THEY... oh sorry caps... since they put that "restrictive" tubing in there. Be ready guys, if you're all right that machine should explode in the next 5 seconds.
/Sarcasm
I'm sure they did it like that for a reason, I mean, after all, they DO make the watercooling systems.
Other than their Boreas 12 TEC Chiller (high performance clean easy to install package but very overpriced) everything they make is junk. Srry but Thermaltake Bigwater is probably better than CoolIT Domino and I can find it @ local Microcenter for 50$.
Are those 15 exhaust fans really necessary in the first pic? They're pretty much useless, unless the intake fans equal to the same CFM amount as the exhaust fans..
/Sarcasm
sorry to disappoint you, CoolIT makes great products. TT Bigwater is junk, it wont outperforma good aircooler, CoolIT's Freezone can measure with decent watercooling, its far more reliable, and far more powerful than anything made by thermaltake.
That looks even more rubbish than my scratched and dented (£5 from the dump) case.
1 - 20 of 20 Posts
