1 - 10 of 10 Posts
Originally Posted by TPU
Razer is working on a new ambidextrous gaming mouse called Ouroboros. The mouse was pictured by FCC for its clearance inspection. It reveals a symmetric, edgy design, which is a breakaway from Razer's traditional curvy designs.
Originally Posted by Engadget
Looking for a rodent to help you frag your way through the competition, southpaw style? The FCC may have just uncovered your new best friend: The Razer Ouroboros gaming mouse. Like the Cyborg RAT series, the Ouroboros features a sliding palm rest and swappable side panels to better fit your mitt.
Source (TPU)
Source (Engadget)
Looks pretty cool.
looks a bit like the r.a.t, maybe it will be adjustable like that? if so, i might have to pick this one up, depending on the price
so close yet so far...
sloppy mspaint fix:
if only...
if they give it a laser sensor I hope its something new and without acceleration or other tracking issues, or at least as long as they do their goofy dual sensor thing and allow you to choose the 3.5G optical
also seems likely its wireless and has the hybrid detachable cord like the Mamba does
Read Only
Originally Posted by MarvinDessica View Post
Looks worse than your average Razer product. Probably even more so.
This. It'd better not use the Philips Twin Eye sensor found in the RAT too.
sloppy mspaint fix:
if only...
The palm wrest and side grips are adjustable/removable in the OP. Razer only has optical and PTE sensors right now iirc. However optical sensors tend to perform very poorly at higher DPIs.
If you claw or fingertip grip, that middle section will not be in contact with your hand anyway.
1 - 10 of 10 Posts
