[TPU]Foobar2000 0.9.6
1498 Views 17 Replies 16 Participants Last post by  GSingh
foobar2000 0.9.6 Release Notes
New installer optionsFoobar2000 can now be installed in two modes: standard and portable.
Standard mode
Standard mode is similar to the “install for all users†option in older versions. You need administrative privileges to install foobar2000 in this mode.Portable mode
Installing in portable mode only extracts the installer content and creates additional files that tell foobar2000 to store any configuration data in its installation folder as well as not to alter the Windows registry. Note that it is not possible to edit file type associations with foobar2000 when using portable mode, as that would require changes in the registry.
Media Library behavior changesFolder watchingUnlike all previous versions, the Media Library now automatically tracks changes made to the content of your Media Library folders. It is no longer necessary or even possible to manually remove dead items or refresh the content of the Media Library.
Wine incompatibility
At the time this article is being written, the foobar2000 0.9.6 Media Library does not work correctly in Wine because of bugs/limitations in Wine itself. Changes in the Media Library folders may not be noticed by foobar2000 until it is restarted.
Hidden and system files
The Media Library now respects hidden and system flags; files or folders with those flags will be ignored. This can be used to selectively hide cuesheets or files referenced by cuesheets.
Limited compatibility with outdated components on Windows VistaTo permanently address the “bad allocation†bug present in very old versions of the foobar2000 SDK (released before 2006-07-30), foobar2000 now refuses to load components built with affected SDK versions when running on Windows Vista. Affected components can be fixed by just recompiling them with an updated version of the foobar2000 SDK.
Cuesheets in added folders ignored by defaultIn recent years it has become a popular trend to include cuesheet files with albums in various music trading communities. Such files introduced behaviors confusing to new foobar2000 users: each track of the album was listed twice. To address this issue, cuesheets are now ignored by default when adding entire folders as well as in the Media Library. You can change this in Preferences ⇒ General and Preferences ⇒ Media Library.
Built-in Matroska support
You should uninstall any third-party Matroska related components before using foobar2000 0.9.6, having them installed will only cripple the functionality.
source
Download
1 - 18 of 18 Posts
Originally Posted by falven
and this is...
foobar2000 is a lightweight and fully customizable media player. With all the available plugins and skins its the best media player out there in my opinion.
Ive had this for days?
0.9.6 has been out since November 08?
Thanks for the info. This is the best audio player bar none....
Originally Posted by DanNEBTD
EDIT lol at trying to bad a smart ass and FAILING . . its a media player . . a damned good one at that
http://www.foobar2000.org/
Yea, fail is right. I quick google would have provided the answer in his case.
Love this media player and with my sound card. Playing all music at 5.1 Surround and not the cheap copy same sound to all speakers type of surround.
Is it better than WinAmp?
Foobar is amazing. I run it on my 1000HE with 1gb of ram with a movie playing and firefox open and it doesnt lag at all....on power saving mode. Its great because its so lightweight.
flac > foobar > prelude > DT-990s
bliss
so yes, foobar is an awesome player.
lol, nah . . originally I posted this link with a smart ass comment . .then when I clicked the link to double check it and read the page i realized my ignorance
bliss
Flac is what audiophiles use right? I just convert all those files to MP3.
I gotta get fubar then.
0.9.6 isn't new at all...TPU was pretty late in posting that for download.
Foobar2000 > all.
Someone tell me how to (privately or public) make Foobar behave JUST like iTunes library and i'll switch permanently. I just don't like it "managing Folders" because most of the songs in the folders are not sorted or named accurately. I click on a song in windows explorer and I want it to show up as a part of a whole library and not just in it's own playlist. someone help me.
EDIT: I also want to be able to edit the song info IN foobar just like itunes.
Interesting. I've been satisfied with Itunes and never really tried anything else. I'm gonna try this out looks very lightweight which is a good thing to me.
http://yuo.be/ipod.php
There you go.
There you go.
Well I don't want it to look like Itunes or have ipod support. I just want it to behave like itunes. I get really frustrated when I open an mp3 from windows and when foobar opens it, it's JUST that song and all the songs from the playlist are gone. It has like no dedicated library.
1 - 18 of 18 Posts
