1 - 4 of 4 Posts
http://www.techpowerup.com/219175/jedec-updates-groundbreaking-high-bandwidth-memory-hbm-standard.html
JESD235A leverages Wide I/O and TSV technologies to support up to 8 GB per device at speeds up to 256 GB/s. This bandwidth is delivered across a 1024-bit wide device interface that is divided into 8 independent channels on each DRAM stack. The standard supports 2-high, 4-high and 8-high TSV stacks of DRAM at full bandwidth to allow systems flexibility on capacity requirements from 1 GB - 8 GB per stack.
So if they start now, when is the earliest we will see big Pascal or AMD's equivalent?
I <3 narcissists
I am not sure how your question really relates to the article. While the cards you mention are slated to use HBM I don't see how we could extract an expected launch date from this bit of news.
Call me VSG
1 - 4 of 4 Posts
