inb4canitbeatalappedtrue
Yet to be released worldwide, the Kabuto CPU cooler by Scythe made an appearance on the company's Japanese website. It is designed to be a high performance stock-cooler replacement for Intel sockets x478, LGA-775, and LGA-1366. All AMD desktop sockets since s754 are supported. Measuring 124 mm (l) x 133 mm (w) x 132 mm (h), the cooler seems like a complex work of metal: A CPU contact block doubles up as a small heatsink. From it, arise six copper heatpipes. The heatpipes, in groups of two, convey heat to three independent aluminum fin stacks. A 120 mm PWM-controlled fan, operating at speeds of around 1300 rpm blows air onto the three fin stacks. At those speeds, its noise levels remain around 26.5dBA. The cooler tips the scales at 730 g (around 1.6 lbs). It remains to be seen when Scythe announces this cooler worldwide. ![]() ![]() ![]() ![]() |
