When does it evolve into Kabutops?
The Japanese saying "Fasten the strap of your Kabuto after a victory" is comparable to English "Do not rest on your laurels" and can be told as a motto for the new Scythe Kabuto CPU cooler. The new Top-Flow CPU Cooler of the Japanese cooling specialist Scythe Co., Ltd. (Tokyo, Japan) is named after the famous Japanese samurai helmet, and has high performance paired with low noise. Slip Stream 120 mm PWM fan mounted Scythe Kabuto on top of the CPU cooler is already known by Mugen 2. Due to its mounting on top of the cooler, the fan not only dissipates the heat of the cooling fins effectively but is cooling down sensitive components on the motherboard additionally. ![]() ![]() ![]() ![]() ![]() Kabuto uses the M.A.P.S. (Multiple Airflow pass-through structure) which is already known from Mugen 2, which utilizes the airflow of the fan PWM Slip Stream in an optimal way. Orientation of the screw holes of the mounting plates in a square allows4-way assembly of the cooler which gives users the opportunity to adjust the cooler perfectly to the conditions in its PC case. In addition, the mainboard compatibility of the cooler is increased. Kabuto CPU Cooler will soon be available on the market for an MSRP of $48.00 excluding TAX / €32,95 excluding VAT. Specifications: Weight: 730 g / 25.74 oz (without accessories) Dimensions: 124 x 133 x 132 mm / 4.88 x 5.24 x 5.20 inch Noise Level: 0 - 26,5 dBA Airflow: 0 - 126 m³/h = 0 - 74.25 CFM Fan Speed: Scythe Slip Stream PWM 1.300 rpm Compatibility: Intel: Socket 478 all Speeds Socket T / LGA775 all Speeds Socket LGA1366 all Speeds AMD: Socket 754 all Speeds Socket 939 all Speeds Socket AM2 all Speeds Socket AM2+ all Speeds Socket AM3 all Speeds Socket 940 all Speeds Accessories: Screws, Mountingclips, Thermal Grease |
