[TPU]Zotac Expands its GTX 285 Lineup, Uses Accelero Xtreme Cooler
4984 Views 23 Replies 15 Participants Last post by  killerhz
Zotac has yet another GeForce GTX 285 SKU in the making. This time, it plans to use its own-designed GTX 285 PCB with an Arctic Cooling Accelero Xtreme GPU cooler. Zotac isn't using the entire kit, as the NVIO2 and VRM heatsinks aren't compatible with this PCB design. Other manufacturers using this cooler for similar graphics cards include Galaxy, which uses it for its GTX 285 2 GB, and Inno3D, which uses the entire kit for its GTX 280 accelerator.
With the new PCB design, Zotac rearranged the card's VRM area. The design differs from another PCB design for the GTX 285 Zotac designed earlier (read here). The card uses 6 vGPU + 3 vMem power phases. Ferrite-core chokes are made use of, and an extra vGPU phase has been added for redundancy and stability (angled chokes next to the power connectors, pictured below). 1 GB memory across a 512-bit interface is present, with the company making use of Hynix N3C 0.77 ns GDDR3 chips. The SKU is almost ready to be announced.
source
if repost let me know
1 - 20 of 24 Posts
Now they're all doing it. It looks awesome as hell though.
I know I say it in every thread that involves the accelero cooler, but Ill say it again: damn I want one of those coolers for my gtx 280
then buy one
there only 60$ lol
I would buy one, but i feel it would be a waste, since I plan on watercooling them in the next couple months....
After that hefty purchase, though, I won't be upgrading anything else anytime soon, lest my wife should kill me.
thanks raffy but no one has them in stock yet
wow does that fit the 55nm GTX 260? The product page doesn't exactly go into detail.
yes I believe it does
no problem, for spending money on xtra air cooling is pointless since i switch video cards all the time plus most of the time your not going to get better overclocks neways. but i wish evga and/or xfx would come out with some sick coolers for their video cards like this one.
for me its not about oc'ing (my xfx gtx 280 is slightly factory clocked) its about it not hitting 80c under load. I recently changed my intake case fan to a good quality hi cfm fan, and added a rheobus extreme controller. now under load, when I jack the intake fan up the card maxes out at around 67c (way better than 80c and not bad for a 65nm chip)
So if this accellero cooler thing can shave off even half of what it claims, my card should top out at somewhere around 50c. Thats slightly above current idle at the moment. (all tests done at 72f room ambient)
so does anyone have one ? how close does the oc'ing get to the nvidia bios limits ?
That's one hot card.......I want that cooler for my GTX 260. That or WCing....
tooooo big, those Fans make it 2.5 Slots =/
Ok I'll found a review of this on an EVGA GTX260 55nm... in German.
and it drops the temps pretty good...
Source
I'll guess that the GTX285 will get overclocked good with this cooler.
I need to make sure I keep some money on hand. I have to buy two of those coolers for my GTX 260s as soon as they are available!
killerhz +rep
Just a small proviso...
My Asus 4870X2 uses a similar tri-fan design.
It takes 3 slots total while in use so those considering using two on a pair of GTX260's for example should make sure that their board has sufficient clearance and that they don't need to plug extra pci-e cards in (sound for example)
Thats cool!
Looks very similar.
1 - 20 of 24 Posts
