1 - 20 of 22 Posts
ZOTAC International, a global innovator and leading manufacturer of graphics cards, mainboards and mini-PCs, today releases a new version of ZOTAC FireStorm, a user-friendly overclocking utility with advanced features that enable enthusiasts to finely tweak and tune their ZOTAC GeForce series graphics card to extract every ounce of performance available.
Source
Basically another re-skin of MSI afterburner?
Implying afterburner isn't just a skin of Rivatuner?
Originally Posted by tsm106 View Post
That was just being contrary to be contrary?
DON'T SASS ME, SIR.
I've had enough of your sassage.
Wait...that sounds bad...
Originally Posted by icanhasburgers View Post
EVGA precision allows 1175MV, yet this only allows 1150mv? Derp?
Nevermind i am mistaken. 1150 in both, which is really, really weird since i swear i remember it was 1175... i'm absolutely sure of it.
WaterCooler
Originally Posted by Raven Dizzle View Post
DON'T SASS ME, SIR.
Thanks for the afterlunch lulz.
Ah great. I will remove MSI afterburner and use this as I have a Zotac GPU. Maybe it benefits ;)
Is there FPS locking with this software though? or FPS monitoring with vram?
You have an nvidia GPU
I like computers
I'll probably try running this instead of Afterburner, if only because it matches my build better. As long as it can do fan profiles/adjustment, can't see why not.
Just tested it
Yes you can do fan profiles with it and can OC very well
but I couldn't see FPS locking, nor any on screen display for games such as FPS, Vram usage, fan speed, temperature etc...
I think the software needs to evolve.
I like computers
Just tested it
Too bad about the OSD though. I never really use it much anyway, since I always have Afterburner open on my second display. Will try this out in a few minutes anyway, I still think it will do what I need it to. I like to know vram usage, but as long as I can leave some type of window open on my second display, that should hopefully work. I use FRAPS for on-screen FPS and screen captures, so that won't be a big deal.
Yeah this might answer your needs very well
One thing I noticed was with MSI Afterburner my Zotac 670 4GB was only allowed for 80% fan profile.
With this software I am allowed to go as much as 100%
Not that I use anything over 75% and no need to, but its still good to know that you can go 100% if you need to.
I've always been a big Zotac supporter (i.e. fanboy), and this was long overdue, the old firestorm was buggy and didn't work well, I might give this a try, but I've never been one to OC Gpu's anyway (hence why I wasn't aware the 680 i sold could do 1300 core folding at 65c, and yes it was Zotac)
DON'T SASS ME, SIR.
Sigged
No you`re right PreX 3.0.4 has 1175, dont know about 4.0, I switched to GPU Tweak, and my drivers stopped crashing, might have to do with Tweak also only allows 1150.
1 - 20 of 22 Posts
