ADATA Nobility USB 3.0 Flash Drive
Flash Drives have been around for almost a decade and have seen a number of technological advances improving performance, size, power and data density. Originally designed as an upgrade over a floppy disk for moving data physically from one computer to another, the modern flash drive has about as many uses as there are types of flash drives available. Transferring family photos to another family member’s computer without needing to send them over the internet, a simple means of transferring driver and updates to a fresh OS install, or even installing an operating system like Windows or Linux can all be accomplished with a flash drive. One thing has not changed though, the standard flash drive is more costly per GB and no faster than an optical disk. Advances in NAND storage technology have improved the speed at which solid state memory devices can transfer data, along with a new faster bus to handle the capabilities it brings to storage technology. The ADATA Nobility N005 USB 3.0 (Or Super Speed USB) advertises a Sustained Read rate of 85MBps with writes of up to 55MBps. This is nearly 3x the throughput of a standard “fast†USB 2.0 flash drive |
