1 - 6 of 6 Posts
Hey guys, I plan to add a 3rd 7970 to my loop and was wondering if my 360 rad + 280 rad with the D5 Vario Pump w/pump top will suffice in cooling them? I will only be OCing my 4770K to 4.5ghz
They will be able to cool fine, but how good depends on the radiators and fans/fanspeed.
+120 for headroom. You are going to be right on the edge. You will need fans of at least 2000RPM I would say to get temps you are happy with. That or you could invest in another 120 radiator and stick it as an exhaust.
Originally Posted by Midnite8 View Post
I have an extra 120 rad I can use, where in my loop should i put it?
My current config:
Pump-280rad-gpus-cpus-360rad-res
Put it where it's convenient and easy to plumb in.
1 - 6 of 6 Posts
