if money isn't an issue you can get another 5970 for quadfire and then you can use a PCI card for physx instead of a PCI-express ...if you have an open PCI slot
they make PCI versions on the 9500GT, that way you will have the best visual experience possible for your given setup
you really only need a PCI-E 8x slot to run a physx card aswell, so if you have an open 8x slot that will be able to run a gts 250, 260 or even a gtx 275 most likely so you can have 2x 5970s and a gts 250 for physx and beast through batman and mirrors edge like its a joke
