1 - 9 of 9 Posts
Nothing turned out the way I wanted. I was tolded to use a Polarized filter and a 9 stop ND filter to get the glassy water look with long exp and also reduce Glare and LEns Flare. Not sure what went wrong. Settings were ISO 100, F/22, and long exposire of 15sec. I tried some shorter ones with lower F-stop but it did not seem to help. Everything turned out soft and had too much noise in it even at low ISO. No clouds today which was a bummer. I thought this camera would not show so much noise on such a low ISO. I set exposure so that the meter read 0 every shot.
First pic is untouched version and second is PP'd with auto WB and added clarity and some noise reduction which did not seem to work. I am using a trial version of Lightroom 3. The image quality degraded after resizing to post here. I will have to put them up on photobucket and link them.
Ok, a lot of factors here at work:
1. Using filters, especially when stacking them, can dramatically reduce IQ.
2. So does shooting really narrow apertures like f/22, where diffraction comes into play.
3. You aren't close enough to the water to really show significant blurred movement from the water. Furthermore, a placid lake isn't a good candidate for slow-shutter water shots since there isn't much movement.
4. Move to a different vantage with more interesting things in the foreground, such as closer to the shore. This will also bring the water closer to the frame.
5. Long exposures increase digital noise due to the heat that builds up in the sensor. Make sure long exposure noise reduction is on, and/or shoot shorter shutter speeds.
THanks for the info that helps a lot. There were hardly any waves at the beach in that area because it is a channel for the boats to come in. Most other active areas of water were crowded or you cant get to it because there was no parking. I will try again. I have seen several people taking long exposure shots that look really nice with no noise in the pictures at all. I guess I will try it agian without the ND filter and just a polarized. I only did both because I was thinking the direct sunlight would damage the sensor.
I have taken night time shoots with up to 3min exposures and did not get much noise for some reason. The entire point of the ND filter was to be able to get that nice look to the water. I watched a vieo of a guy using one that did a 2 min exposure to get that perfect glassy look. He set the camera at F/22 and 100 ISO in order to get that long, and it was an overcast day if I remember. I knew I would not get that long on a sunny day. I thought I had long exposure noise on but i checked and it was not. I reset the cmaera settinga couple of day ago and forgot about it.
I will go back and try agian without filters and see and try a different area. I figured maybe I damaged the camera is why the pics did not come out right.
Try metering off the sky or even the foreground (exposure lock button). Metering off the sun is probably bumping up the shutter speed.
Originally Posted by sub50hz;15236157
That's not a 9-stop ND. Not at those settings.
Hard to say, it looks like the camera is metering right off the sun, so the SS without a filter would be something like 1/300".
Discussion Starter · #8 ·
It is a Hoya ND400 and I checked in the papers it came with and on their site and it says it is a 9 stop. I called the camera store I bought it from and asked if I should be able to see anything through it at those settings and they said yes in bright sun light I will still. On a cloudy overcast day it will be much darker. I have a B+W 10 stop coming and I will compare though. IF it is significantly lighter than the BW 10 stop then I will take it back.
Originally Posted by sub50hz;15236223
Not at f/22 + ISO100 for 15 seconds. At that time of day the sun moves so rapidly that it would be a pretty sizable streak.
Discussion Starter · #9 ·
I will try that today. Should I use any filters at all though?
1 - 9 of 9 Posts
