1 - 6 of 6 Posts
I tried to overclock my Intel Q8300 from 2.5GHz to 3.00 GHz. From what I've read this is easily doable. Well, this was my first attempt at overclocking and I wasn't sure what I did. Basically there was something that said FSB : 1333 MHz ( or something very close to that ) and I changed it to 1400 MHz. This increased it to 2.62 GHz , so I increased it higher to 1450. I saved and exited my bios, but the computer froze. I manually turned off my desktop and restarted it, but it's not stuck at the screen that says: press Delete to enter Bios and press Tab to view Bios message. It's stuck at that screen and I pressing delete or tab doesn't do anything.
Not new to Overclock.net
Oh, you'll need to reset the CMOS chip. Which motherboard do you have?
Oh wow, you did it! hehe Cool. :)
Anyway, wow, you have a motherboard that's not very good for overclocking at all. I'm surprised you got as far as you did with it.
Damn, oh well. Thanks for the help though. At the very least I got my computer back. By the way, do you think I would even notice a performance increase if I raised it back from 2.50 GHz to 2.60 something-ish?
I doubt it because it's only a 100 MHz difference compared to the 2500 MHz you're at now.
1 - 6 of 6 Posts
