troll?
Or maybe you are the troll... why bother posting if you are not going to even try to helpOriginally Posted by snoogins;13108161
troll?
he has a 590... which has internal SLI...Originally Posted by Cmoney;13108218
Or maybe you are the troll... why bother posting if you are not going to even try to help![]()
Like the other posters have said, it is just a matter of getting 3 of the same monitors, enabling the multi-monitor setup in your NVIDIA Control Panel, and Viola! Game compatibly should not be an issue with a single card; most people run into problems when they are running SLI/Crossfire if games don't properly support itHope that helps.![]()
3 screen @ 1080p = 5760x1080Originally Posted by manu97416;13108235
am i supposed to get a special res or something?
Sorry just woke up... I thought I had read 580 instead of 590... and I know very little about NVIDIA Surround so that is good to know. Too bad he didn't just get an eyefinity cardOriginally Posted by hodgoes2001;13108240
so same issues as everyone else...
but that is also the reason why he only needs 1 card...
because of Nvidia Surround... you need 2 cards in SLI...
which i can actually understand...
because it is literally 3 times the amount of work
so to run new games at high or maxed settings.. you will need more then one card...
but as i said.. his card is pretty well a 2 in one
Yes, all crysis games (first one, warhead and 2) support surround.Originally Posted by manu97416;13108178
my question is if crysis supports?
i have nothing against ATI... i still own one of there cards...Originally Posted by Cmoney;13108292
Sorry just woke up... I thought I had read 580 instead of 590... and I know very little about NVIDIA Surround so that is good to know. Too bad he didn't just get an eyefinity card![]()
I honestly thought he was trolling... my badOriginally Posted by Cmoney;13108218
You are taking too much credit from today GPUs.Originally Posted by hodgoes2001;13108330
but from what i have seen myself... one GPU can't keep up with 3 screen with a high graphics level set...
yes i do like the fact that with ATI/AMD you only need one card for 3 or more screens...
but it is a bit of a let down when you have to have your grahpics really low in order for it to run smooth...
it would be like running 3 screen on 460... i wouldn't recommend it
yes it would work...
but they wouldn't be powerful enough to enjoy it
so you have 3 screen with the same max res?Originally Posted by manu97416;13108325
it says i cant have 3 at once only 2 so is it possible to play on 2 or is there a special cable i need?
