1 - 5 of 5 Posts
Ok, here's the stiuation. i built my comptuer yesterday, and installed xp pro on one of my seagate ata 160g drives. after everything was finisehd and i load xp, only one of my drives shows up in my comptuer. menaing, i can only use one of my drives. both show in device manager, but only one has the option to enable/disable.<br><br>
how can i get this second drive working?<br><br><br>
coudl it have happend that it took the entire 160 g drive to install xp, and is using that only for xp?<br><br>
also, i made sure the jumpres on the slave drive were correct.
Update, thanks for all the help! <br />
<br />
anyways, i fixed it. i ended up having to go into cpanel>admintools>comp management. then format through there. now i'm worth 160 more gigs
Normally someone gets to threads like this. Oh well. glad you got it figured out.
Discussion Starter #5
Haha it was probably better this way, made me stop being lazy and figure it out <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps"><img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps">
1 - 5 of 5 Posts
