1 - 7 of 7 Posts
greetings ,i recently purchased a viewsonic 2025 . i have been useing this monitor for about 2 weeks ,everything was great . <br />
last evening , i was gameing and browesing ,as usual . i left the computer to grab a coffee . about 20 minutes after , a came back to the computer .i found that the monitor had gone into stand by mod . [the screen was dark ,as usual ] . i moved my mouse , to bring it back , as ive allways done ,and no go . i hooked up my old crt , and it worked . i rehooked up the viewsonic , no go . <br />
i even reformatted my c drive . still no go . <br />
im kind of dissappointed , to be sure . its a great monitor .<br />
i dont know what happened . it just went to sleep , and wont wake up . <br />
if you people could suggest something for me to try , i sure would apprecitate it .thanks for reading . ANY help , would be great .<br />
cheers .
try swapping the connectors to the graphic card<br />
<br />
also you might wana look under control panel-power options<br />
<br />
<br />
have you tried the monitor on a different pc ?
Plug the CRT into one port on the graphics card, get into Windows and then plug the VX2025 into the other port and see if it is detected as a second monitor.
Discussion Starter #4
<tr>
<div>
Originally Posted by <strong>muffin</strong>
</div>
<div style="font-style:italic">Plug the CRT into one port on the graphics card, get into Windows and then plug the VX2025 into the other port and see if it is detected as a second monitor.</div>
</td>
</tr>
</table>
</div>in the nvidia controll panel , my 2 monitors are there . <br />
when i shifts to the lcd , my crt goes black , <br />
after a minute or so , it comes back on . <br />
the lcd does nothing . <br />
anything else i can do??<br />
thanks so much for replying .<br />
cheers .
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>mootin</strong>
</div>
<div style="font-style:italic">try swapping the connectors to the graphic card<br />
<br />
<br />
<br />
have you tried the monitor on a different pc ?</div>
</td>
</tr>
</table>
</div>its been working great .<br />
i had it only 12 days .<br />
i didnt change anything .<br />
power options??<br />
what will i do??<br />
thanks for replying .<br />
cheers .
Did you install drivers for the VX2025? If you did, try reinstalling them.
Discussion Starter #7
<tr>
<div>
</div>
<div style="font-style:italic">Did you install drivers for the VX2025? If you did, try reinstalling them.</div>
</td>
</tr>
</table>
</div>no , i didnt . i was told to just plug it in , and play . <br />
thats what i did . it worked great . its only 12 days old .<br />
strange ..<br />
ill load the drivers , to see what happens .<br />
thanks again . <br />
ill post when the drivers are loaded .<br />
cheers .
1 - 7 of 7 Posts
