1 - 20 of 20 Posts
Hello, guys. First of all I'll start with my specs.
Cooler Master HAF 932 Case
Cooler Master Silent Pro M 1000W PSU
AMD Phenom II x4 965 Black Edition 3.4GHz
Asus M4A88TD-V EVO/USB3 Motherboard
Mushkin Enhanced Silverline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 996768
Seagate Barracude 1TB HDD (SATA)
EDIT: Also, my Video Card is an ATI Radeon HD 5770, but I haven't even connected it yet due to the PSU not even turning on.
For some reason my PSU isn't turning on when I try to power up the computer. I'm not sure if the system panel connectors could cause this, but i'm pretty much sure i hooked those up right.
It's been a few years since I built my last computer, so I have another question. On the motherboard I currently have, I connect one of the 4x4 CPU pins to the motherboard 12v EXT spot correct? Where do the other three that the PSU have go?
Any help would be appreciated
-The Noob.
Did you plug in the CPU to the outlet? and connect the 12V ATX motherboard plug? And connect both 4pin 12v to the motherboard. You have a 8pin connector so put the 2x4pin together and connect them.
Man with Fans
-The Noob.
The problem is that your PSU isn't turning on?
I'd like you to try it from outside the rig.
Unplug every cable from your parts, and use a piece of wire to short the green wire to any black wire on the 24-pin ATX connector.
Then plug the PSU in to a wall socket and see if it turns on.
If it turns on when isolated from your rig, I suspect a short in your rig.
Discussion Starter #4
I did plug the CPU into the outlet right next to where the heatsink and everything is installed.
The 12V ATX motherboard plug is located where?
I do have two of the four 2x4 pins connected, but there is still two more.
EDIT: When I do try to power on, while switching the power supply to off, it does make a very faint tick. That doesn't mean it's shorted does it?
EDIT 2: Also, the system panel connectors need to be connected to cause the power to turn on right? I'm having a hard time connecting those because the lettering is so small and half the damn words cover two or sometimes three spots.
Its the 20+4 pin that goes to your motherboard
Make sure the breaker on the psu is in the correct positon (toward the -- and not the O)
And make sure the psu has the correct voltage selected (110 or 220)
Discussion Starter #6
There is no voltage selector on the outside... I haven't looked on the inside.
I do believe the Silent Pro 1000w has features automatic full range (100V-240V) AC line voltage selection, as is the case with most modern power supplies.
EDIT: I have the fan that is on the top of the case running to PWR_FAN, the fan to the rear of the case to CHA_FAN, the PSU to EATXPWR, CPU fan to CPU_FAN, and also have the PSU connected to EATX12v using two 2+4 connectors and still have two more from the PSU. Hopefully someone can find what I'm doing wrong.
Does your mb have a power indicator? A little LED to show it has power?
I bet you have the power on backwards. Take something metal and bridge the pins for power on and see if it boots
Discussion Starter #8
Can you explain that in simple terms? I'm a little lost.
What connections do I have backwards? Can't I just switch them?
Make sure the colored wire is on the + power button and the black wire is on the -
Discussion Starter #11
Are you talking about the system panel connectors?
Yes
Discussion Starter #13
I believe the system panel connectors go in this order from left to right:
IDE LED (for the HDD I'm assuming....), +P LED, and -P LED...
EDIT: Problem is I can't find a diagram for which connectors go to which prongs... It's honestly confusing me... Never had this many issues with a motherboard or a PSU for that matter. Only the + and the - connectors have to be connected to the system panel for the PSU to turn on right? I'm not even worried about the motherboard or anything right now. I just want that damned PSU to turn on.
touch something metal to the + and - for power and see if it fires up
Discussion Starter #15
The the prongs on the motherboard? That's the problem, the diagram on the motherboard itself is so jumbled up, to be honest, I don't even know if I'm putting them on the correct prongs. I mean, I'm not a ****** by any means, but I am seriously starting to doubt myself lol.
System panel wiring:
HAF 932 system cable colors (of each wire pair):
H.D.D. LED:....... Red + / White -
P.LED:............... Green + / White -
Power Switch:.. Orange + / White -
Reset Switch:.... Blue + / White -
Note: White is always - (ground)
Connection - cable colors:
oh tehe, maybe you got the +/- mixed up on the power botton. on the pic described above, if you think you have them in the right way, flip them around. xD
Discussion Starter #19
I followed that diagram, still no power. I swapped the + and - around opposite the diagram, didn't work.
As for the person who posted about the paper clip, there is no black wire.
I see several black wires on the 20+4 connector. Find the green wire, place one end of the paperclip in the hole, then place the other end into a black wire hole. This "fools" the PSU into thinking it is connected to a mobo. Plug in PSU and turn on. If it turns on, PSU is fine. If it does not, PSU is dead.
1 - 20 of 20 Posts
