You mine as well lap your CPU and your TRUE, it should eliminate this problem
Originally Posted by stargate125645 ![]() I thought mine was rather flat, too. Several hours of lapping showed otherwise: http://www.overclock.net/intel-build...nighthawk.html If the base is curved it will make much more than a few degrees difference. Also, the extra fan on the end may not appear useful but many users claim that higher static pressure will improve cooling efficiency for a TRUE, and doubling the fans will increase the static pressure. |
Originally Posted by andygoyap ![]() Okay thanks! i am wondering how much temp improvements did you get after lapping, or you went straight to lapping ? hehe.. i wish i could buy those kits in my country. |
Originally Posted by stargate125645 ![]() I haven't tested it on a system yet, so I couldn't tell you. When I lapped my Tuniq Tower 120, I saw a mimimum 2 degrees C difference, but the Tuniq Tower 120 base was flat and the TRUE base is not, so I would expect to see double the improvment at minimum. EasyPCKits will ship overseas. It says so on their front page, in fact ($12 flat fee for air mail). I suggest you follow the techniquies I have outlined in my build log if you are worred you will damage something. Just don't put pressure on the fins or the heat pipes and you'll be fine! |
