> TRUE handmade watercooling rig - PHOTOS <
3301 Views 24 Replies 18 Participants Last post by  MADMAX22
5
here is my friend's rig. every weekend he needs to have a project with it - usually to do with his watercooling.
he is obsessed about copper, having so much of it lying about he crafted himself CPU block, NB block, GPU block, VDDA block, he used to have a custom made watercooled RAM heatsinks where copper pipes wealded to copper plates hugged RAM chips - it was taken out when he realised that new DIMMs dont have removable heatspreaders. recently his software fan controller was overheating in horisontal position so he crafted a copper plate for it also. at the front bottom there is a watercooled sound isolating box for 2 raptors having its own custom made cooling solution where copper pipes are huging them. all this is cooled by ultra quiet 38mm Sythe fans blowing through two 240x120 radiators all attached to the rig - one on top & another through the back. overall the rig is silent as this is what he was trying to achieve.
so what do you think in regard to his first ever build?
1 - 20 of 25 Posts
What tubing is that? Looks kinda cheap.... did you get any pics of the inside of the CPU block?
Looks great.
Although the tubing looks a bit thin? Or the CPU block is just massive.
Originally Posted by honk_honk View Post
Looks great.
it is thin but the guy didnt even read any of the guides on how to build a water rig. he literally just used his common sence. tube is just something he found in garage i think. u see he only uses what he finds around him - its a challenge to make things work.
tubing looks thin it dont look like it would have a good flow rate what pump is he using and whats his load temps like?
Looks like 3/8 if so it's as good as 1/2 is when it comes to cooling a PC.
Originally Posted by JMT668 View Post
he needs to find some zip ties!
Actually as stretched as that is on the tubing it wont leak much less easily come off, I would still use clamps IMO but honestly not necessary with as little pressure as we have in our loops.
To the op looks pretty darn good for a home built setup. Actually really good.
Its allways impressive what people can come up with when they put some effort into it.
Nice lil diy watercooling there
only down side is visualy, its horrible to look at, but thats just my oppinion, cant complain since your m8 never did any reasearch on watercooling and just used what was lying around
"Practice Makes Progress"
Looks pretty damn cool if you ask me. Not many people do a FULL DIY system
I appreciate the look of a full DYI system. Props to him for doing it, I know i'd never have the time/skill to accomplish such a task.
The barbs being copper I wouldn't feel good using clamps or zip-ties so I think it's fine the way it is. Great DIY build. I wish I had more metal-working experience to build custom brackets and all that.
So he just happned to have a watercooling reservoir chillin in the garage? Lol.
Originally Posted by the_milk_man View Post
you need to direct your buddy to the "Rate my cables" thread and show him a bit of cable management
i guess its not practical for him sice he takes his rig apart every now & again.
We all take our rigs apart, but cable management is a must if you're putting this much effort into them that we actually want to show them to other people!
You can have great cable management that actually makes it easier to take everything apart.
I think it is very cool. Agree with the cable management. But I appreciate the custom made blocks as I have some myself!
1 - 20 of 25 Posts
