Alright. Right now I set it to 1.42v in the bios (rest of my specs in my signature). It just failed at 1.41v. So if this fails at 1.42v should I try changing the CPU-NB from Auto to 1.25v?
Also, I noticed that in both HWMonitor and HWInfo64 it says that my CPU core temp is about the same as my socket temp. What's going on? Does that usually happen? When I was testing 4.2 GHz the highest the socket and core got were 61 C socket and 51 C core temp. Is it because of the fan over my VRMs?
Yeah I was able to get 4.2 GHz stable at 1.32v and CPU-NB set to auto on 10 hours of Prime95 blend. Its always core 5 that fails.
Yeah when I have CPU-NB on auto the voltage shows up as 1.18v in the bios also.
EDIT: Yeah I've gotten this at 4.5 GHz stable a while ago.
