From the results it looks like Nvidia/Intel hardware is favoured.
I just picked up this game today...gonna try running it with WHQL...if SLI doesnt work I guess I'll try the beta driver.
http://www.techspot.com/review/706-splinter-cell-blacklist-benchmarks/In total, we tested 23 AMD and Nvidia graphics card configurations spanning all budgets. We tested using the ultra-quality preset with FXAA, Field AO, HBAO+ (default), MSAAx4, Field AO and HBAO+ as well as FXAA and Field AO with HBAO+ disabled.
To measure frame rates, we used Fraps to record a minute of gameplay from the first mission. The Core i7-4770K was used at its default operating frequency for all the GPU tests.
Finally, we know that many of you will be interested in CPU scaling performance as well, so we clocked the Core i7-4770K and FX-8350 processors at several frequencies to see what kind of impact this has on performance when using a GTX Titan with the ultra-quality preset. Additionally, we ran similar tests using a range of processors including the Core i7-3960X, i5-3570K, i3-3220 and AMD Phenom II X6 1100T.
We'll look for an average of 60fps for stutter-free gameplay.
