TTPOD T1-E High Definition Dual Dynamic Professional In-ear Earphone Gray
Description:
Technical Parameters: Wearing styles: ear Headphone Type: Wired Whether the microphone: No Plug Diameter: 3.5mm Headphone plug type: straight type Driver:2*6.2mm (unilateral) Frequency range:8Hz-26KHz Sensitivity:104db at 1KHz/mW Impedance: 12ohms Cable: 18 core 0.05mm OFC silver plated cable Cable length:1.3m Connector:3.5mm gold-plated Plug Packing lists: TTPOD T1-E earphone 9 sites of eartips (S/M/L Like the picture shows) A Carrying bag
Details:
Description:
Details:
Detail | Value |
Brand | TTPOD |
EAN | 0674387794922 |
Feature | Conducted on the basis of T1 perfectly balanced version optimized for the preparation of more popular genre with the big tracks IF warmer, deeper distant low-frequency sound field more ambitious unit optimization:Coil diameter increased by 6.8%, double the number to four winding wound, IF fuller, more powerful low frequency Diaphragm optimization: The latest generation of the German original biological membrane, sound density stronger, more adequate amount of information High-quality synthetic material housing: Lightweight high-strength, durable, comfortable to wear 6 times harsh test: The difference between left and right channels is less than 1DB, top international quality standard headset |
Label | TTPOD |
Manufacturer | TTPOD |
Model | TTPOD T2-E |
MPN | TTPOD T2-E |
Publisher | TTPOD |
Studio | TTPOD |
Title | TTPOD T1-E High Definition Dual Dynamic Professional In-ear Earphone Gray |
UPC | 674387794922 |
Package Height | 2.3 inches |
Package Length | 5.1 inches |
Package Weight | 0.35 pounds |
Package Width | 3.3 inches |
PartNumber | TTPOD T2-E |
ProductGroup | CE |
ProductTypeName | ELECTRONIC_SIGNAL_CONVERTER |
UPCList - UPCListElement | 674387794922 |
